__EHH__
Oct 29, 2023Tutor
WAC540 access-point suddenly reboots multiple times a day.
Dear ppl, This WAC540 AccessPoint is powered by a Netgear GS116PP PoE/PoE+ switch, which is powered by a 200 Watt adapter, giving this Switch a total PoE budget of 183 Watt. The WAC540 is the o...
__EHH__
Oct 30, 2023Tutor
Thank you schumaku for your suggestion.
It took me a while to find a free syslog-server but managed to find one that works on my MacBook (SysLogCenter by Lan-Secure).
After 3 1/2 hour the Accesspoint rebooted and I managed to save all the events and notifications recorded by the syslog server. The TXT file is 909kB in size, can I post it here?
The first few events recorded are listed below. The WAC540 has IP address 192.168.1.3 and my Router is 192.168.1.1.
Edwin
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077847] NULL
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077842] LCI_allow_list:
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077834] [wifi0vap2]IEEE80211_LCI_ADD_NW_INFO flag=0, GW=16885952, netmask=16777215, AP_IP=0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077820] [wifi0vap2]IEEE80211_LCI_ADD_NW_INFO GW=192.168.1.1, netmask=255.255.255.0, AP_IP=0.0.0.0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077801] IEEE80211_LCI_ADD_NW_INFO 16885952, 16777215 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077790] CONFIG->GW=16885952 CONFIG->AP=0 CONFIG->NETMASK= 16777215,FLAG=0
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077771] VAP->GW=0, VAP->AP=0, VAP->netmask =0, flag=0
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077652] NULL
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077646] LCI_allow_list:
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077639] [wifi0vap1]IEEE80211_LCI_ADD_NW_INFO flag=0, GW=16885952, netmask=16777215, AP_IP=0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077626] [wifi0vap1]IEEE80211_LCI_ADD_NW_INFO GW=192.168.1.1, netmask=255.255.255.0, AP_IP=0.0.0.0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077607] IEEE80211_LCI_ADD_NW_INFO 16885952, 16777215 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077595] CONFIG->GW=16885952 CONFIG->AP=0 CONFIG->NETMASK= 16777215,FLAG=0
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077579] VAP->GW=0, VAP->AP=0, VAP->netmask =0, flag=0
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077408] NULL
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077402] LCI_allow_list:
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077394] [wifi0vap0]IEEE80211_LCI_ADD_NW_INFO flag=0, GW=16885952, netmask=16777215, AP_IP=0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077380] [wifi0vap0]IEEE80211_LCI_ADD_NW_INFO GW=192.168.1.1, netmask=255.255.255.0, AP_IP=0.0.0.0 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077360] IEEE80211_LCI_ADD_NW_INFO 16885952, 16777215 updated in vap table
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077347] CONFIG->GW=16885952 CONFIG->AP=0 CONFIG->NETMASK= 16777215,FLAG=0
2023-10-30 12:45:09 Kernel.Informational 192.168.1.3 kernel: [ 62.077323] VAP->GW=0, VAP->AP=0, VAP->netmask =0, flag=0
2023-10-30 12:45:09 User.Error 192.168.1.3 syslog: apply_lci_parameters:1086 called brtrunk-192.168.1.3-192.168.1.1-255.255.255.0--
schumaku
Oct 30, 2023Guru - Experienced User
The interesting entries I'd expect would be the last 10....30 entries before the WAC540 does restart, like crash dump information if any.
- __EHH__Oct 30, 2023Tutor
Thanks again. I logged the messages during 3 reboots today. The avalanche of log entries starts in all three cases after this entry:
In the picture attached are the syslog entries immediately prior to the line above for 3 reboots (12:44, 14:48 and 15:24)
Edwin
- schumakuOct 30, 2023Guru - Experienced User
Have configured a static LAG on the WAC540, and two links active on a switch configured for a static LAG?
I don't have a static LAG setup and did double check it.
Edwin
