sdunnin's avatar
sdunnin
Guide
Sep 18, 2021
WAC540 Apple Device Issues
I have a WAC540 access point and am having issues with what seems to be only iOS devices (Iphones and Ipads). The symptom that they experience is random HTTP load and connection issues. For example they will experience a web site that will partially load and then stop. Sometimes reloading will completely load the page, other times it will not. Sometimes pages will not load at all, while on other non Apple devices (e.g. a Windows laptop) it will load just fine. Can't put my finger on any sort of pattern so far but it just recently seemed to become a problem.
The AP is running firmware 9.5.2.4 and it says there is a new version available which I plan on upgrading to this weekend. I have 2 WiFi networks configured. One configured for 2.4 and 5ghz and the other only 2.4 with the latter only being used for iot type devices. All user clients connect to the first network and all Apple devices are using 5ghz with some on Low channels and some on High.
Just trying to figure out how I might best troubleshoot this. Any suggestions welcome.
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi sdunnin
    What is the iOS version? Please download the detailed log from the monitoring page and send it for us.
    You can upload logs into google or one drive and send me a link via PM to download the logs.
    Thanks,
    Raghu.
    • sdunnin's avatar
      sdunnin
      Guide
      Where is the monitoring page located? I have been using the Insight mobile app to manage the device.
      I think all of the iOS devices are running 14.x but probably not all the exact same version.
ProSupport for Business
