Ro-Ko
Jan 09, 2021Follower
WAC540 controlled by WC7500
Our IT retail company mentioned that it would be possible to control the access point WAC540 with the WLAN controller WC7500? I found nothing to get a connection between the WLAN controller WC7500 and the access point WAC540. Searching for WAC540 fails? Has somebody an idea how to control and manage WAC540 by WC7500? Many thanks.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Business Wireless - NETGEAR Communities
I will ask the Netgear moderator to move your message. - RaghuHRNETGEAR Expert
Ro-Ko No you can not manage WAC540 with WC7500. It is not supported. WAC540 is an Insight Managed device. For more info plesae refer -WAC540 - Insight Managed Smart Cloud | Wireless Access point | NETGEAR"
Thanks,
Raghu
