pn23
Aug 02, 2021Aspirant
WAC720 and WAC730 802.11r
Is there anyway to enable 802.11r/seamless roaming/fast transition on these access points? The specification says that they are capable of it, but there is no setting in the GUI. I have tried...
schumaku
Aug 02, 2021Guru - Experienced User
While the WAC720/730 are not intended for Insight, with BC being EoL we urgently need a way to enable 802.11r FT in ensemble mode RaghuHR please. Similar, the Controller-only-feature LED off contrl is baldy missing, too.
- pn23Aug 02, 2021AspirantAh that explains why I couldn't find a way to sign up for BC then. I couldn't find anything to say it's gone EOL. I bought these APs less than a year ago so feeling like I've been stiffed over this.
RaghuHR if the one cloud management system has been retired it does seem pretty poor to not be able to add them to the remaining one.
