called_sepp
Apr 23, 2024Aspirant
WAC720 and WAX610, How to setup a same SSID with this APs
Hello,
can the Netgear WAC720 and the WAX610 work together in the same network?
called_sepp wrote:
,can the Netgear WAC720 and the WAX610 work together in the same network?
Definitively yes:
Either use the same flat IP network, or the same SSID mapped to a VLAN.
Key is using WPA2-PSK (WPA2-Personal) on all access points, because of the WAC7xx does neither support WPA3-SAE nor the Insight supported/-based cloud based roaming.
