alfrede3
Sep 26, 2016Tutor
WAC720 Stability Issues
I have posted this issue before thinking I had a solution. Have to cycle power on both of my WAC720 access points at least once per week. We have tried different firmware versions, setting specific...
- Oct 05, 2016
Hi alfrede3,
It's great to hear that! There must be something wrong with the ensemble mode. I think it's safe to say that we can now mark the post as resolved, I'd like to suggest to you to mark the appropriate post on the thread as "Accept as Solution" so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
JohnRo
Sep 27, 2016NETGEAR Employee Retired
Hello alfrede3,
It would be better if you open a ticket with our Support Team. I do not see a logged issue similar to what you are experiencing, it is best to let the engineers check if this is a bug or an isolated issue. They may ask you to run a network diagnostic software (like Wireshark) and send the captures to them so that they will identify the issue.
Thanks,
