PatPend
Sep 05, 2017Aspirant
WAC720 STILL LOCKING UP - FIRMWARE 3.7.11.0
 I have two WAC720 access points configured in ensemble mode that are locking up hard and require a power cycle to regain connectivity.  Both access points are powered by POE and connected via CAT6 to...
- Sep 08, 2017
Beta firmware is installed on both WAC720s and a factory reset on both was done afterward per instructions. Since I had to reconfigure from scratch the new configuration may not be 100% exactly as it was before, and I haven't reconfigured the captive portal yet. No issues in the 12 hours since the upgrade. Typically one or both units would lock up within a day to a week, so I'll continue to observe and advise. Thanks for the swift response.
RaghuHR
Sep 05, 2017NETGEAR Expert
Thanks. Our support team will reach you for further formalities.
Best regards
Raghu
PatPend
Sep 06, 2017Aspirant
Thanks Raghu. Any idea of the timeline?
- DaneASep 07, 2017NETGEAR Employee Retired
I have sent you a private message regarding the Non Disclosure Agreement about the potential fix that RaghuHR has mentioned to you. I will be waiting for your reply.
DaneA
NETGEAR Community Team
I got your private message and already replied to it with the download link to the beta firmware for the WAC720. Kindly follow the directions indicated in my reply. Let us know your observations here on this forum thread.
DaneA
- PatPendSep 08, 2017Aspirant
 - DaneASep 25, 2017NETGEAR Employee Retired
Thanks for the update. I'm happy to know that the WAC720 APs have not locked up and the wireless connection is just fine. :)
Since it seemed that the beta firmware solved the problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community will look forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
- PatPendOct 07, 2017Aspirant
I just received the security update alert. Can I safely upgrade from the beta firmware I received to the latest 3.7.12.0 without issue? And is a factory reset + full reconfiguration required? Thanks again for all your help.
