just_luc
Jan 25, 2018Tutor
WAC720's no longer broadcasting after firmware upgrade on WC7600 controller
Hi all, I performed the firmware upgrade on my wc7600 controller to 6.5.3.2 last night. I followed the upgrade path and loaded the migration firmware first. All seemed to go well, all AP's took t...
- Jan 28, 2018
For the 2 WAC720 access points, Kindly try the steps below:
1. On the web-GUI of the WC7600, go to Configuration > Wireless > Basic > Wireless.
2. Click on either the 802.11b/bg/ng and 802.11a/na/ac tabs. Is there a check mark on Turn Radio On on both he 802.11b/bg/ng and 802.11a/na/ac tabs?
- If yes, uncheck Turn Radio On then click Apply. Then, check again Turn Radio On and click Apply.
- If no, check Turn Radio On then click Apply.
3. Observe if the WAC720 WiFi LEDs are lit up.
If ever the WiFi LED lights are still off, kindly try to set the 2 WAC720 as standalone access points then observe if the WiFi LEDs will lit up.
For the 2 WNDAP360 access points, I suggest you to open a chat or online case with NETGEAR Support at anytime. The NETGEAR Support Team will help you to recover the WNDAP360 access points. Also, if ever the problem is still the same with the WAC720 access point, they can also help you with it.
DaneA
NETGEAR Community Team
DaneA
Jan 28, 2018NETGEAR Employee Retired
DaneA
- DaneAFeb 01, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to perform the steps suggested? If yes, what is the result?
Also, were you able to open a chat or online case with NETGEAR Support regarding the recovery procedure of the WNDAP360?
DaneA
NETGEAR Community Team- just_lucFeb 03, 2018TutorHi there, I attempted to uncheck and recheck they wireless as recommended. This didn't help.
I haven't yet gotten a chance to revert them to standalone mode, I'm not quite sure how either.
And no everytime I try to open a chat with netgear it says the chat is unavailable.- just_lucFeb 05, 2018Tutor
how does revert the AP to standalone mode? I tried just loading the standalone firmware and it says the AP is managed upgrade cannot be done..
