sschiang's avatar
sschiang
WAC730 - Not power up
Our company brought a 3 pack of WAC730s, 2 of those were put into service sometime ago. I tried to put the third one in service but after connecting to a POE switch (as with the other 2), none of the...
  • sschiang's avatar
    sschiang
    Jun 06, 2017
    Hi David,
    This turned out to be a 802.3af issue. The other two WAC730 work because they were connected to the only two af ports on the Meraki switch (I did not know the switch only comes with 2 af ports). Once the issue is identified, the fix is fairly straight forward, I think all I need is to get a POE af injector and that should do it. Thanks you for the help.
ProSupport for Business
