ebp-d
Feb 03, 2016Aspirant
WAG102 -> web management with RC4 not supported (chrome browser)
Chrome Browser doesn't support accessing web interface of Netgear WAG102 access point. ERR_SSL_VERSION_OR_CIPHER_MISMATCH Will there be a firmware update regarding SSL security?
- Feb 04, 2016
Hi ebp-d,
The WAG102 is an old access point by NETGEAR and there has been no new version of firmware that has been released for a long time. For me, I considered this access point as an EOL (End-of-Life) device though its not yet listed in the NETGEAR EOL Bulletin here. I also think that the NETGEAR EOL Bulletin should be updated.
Since you are still able to access the web-GUI of the WAG102 using IE11 tthen I suggest you to just use IE11. Otherwise, you may open an online case with NETGEAR Support and inquire about the WAG102.
DaneA
NETGEAR Community Team
ebp-d
a) using chrome version 48.0.2564.103 m (64-bit)
b) problem occours on every Windows 7 machine using the latest chrome version
c) using e.g. latest Firefox 44.0 it shows "ssl_error_no_cypher_overlap"
using current Internet Explorer 11 still works
d) Firmware V2.0.16
DaneA
Feb 04, 2016NETGEAR Employee Retired
Hi ebp-d,
DaneA
