Blarn_Kranston
Jun 21, 2023Apprentice
WAX-615 2.4 Ghz network dissappears
I have a single WAX615 in my home that is NOT cloud managed. I have it set to reboot every morning at 7:30am to make certain it is running cleanly every day as my wife and I both work from home. ...
- Dec 15, 2023
Hi,
From the logs shared by you, we could find some issue with "Network Integrity Check" feature. We will be improving this feature by fixing the issue in the near future.
For now, we will request to disable this feature. Same can be disabled by going to "Management-> Advanced-> General -> Network Integrity Check" tab.
Thanks!
Pramendra
Blarn_Kranston
Jun 22, 2023Apprentice
Thanks for the quick reply. I originally started the daily reboots because the 2.4 Ghz SSID was dropping. I have turned it off and will see if that helps.
Blarn_Kranston
Jul 06, 2023Apprentice
Well, it took a few weeks, but the 2nd, 2.4 GHZ only SSID dissappeared again. It has not been rebooted at all, as it's on a battery backup.
I am at a loss on how to fix this.
