Blarn_Kranston
Jun 21, 2023Apprentice
WAX-615 2.4 Ghz network dissappears
I have a single WAX615 in my home that is NOT cloud managed. I have it set to reboot every morning at 7:30am to make certain it is running cleanly every day as my wife and I both work from home. ...
- Dec 15, 2023
Hi,
From the logs shared by you, we could find some issue with "Network Integrity Check" feature. We will be improving this feature by fixing the issue in the near future.
For now, we will request to disable this feature. Same can be disabled by going to "Management-> Advanced-> General -> Network Integrity Check" tab.
Thanks!
Pramendra
RennaD
Aug 01, 2023NETGEAR Moderator
Hello Blarn_Kranston,
Please try to update the firmware to version 10.5.0.14. This contains the fix for the issue where the AP stops broadcasting a configured SSID.
https://kb.netgear.com/000065754/WAX615-Firmware-Version-10-5-0-14
Have a lovely day,
RennaD
Netgear Team
- Blarn_KranstonAug 02, 2023Apprentice
Thanks RennaD. I am updating right now and will reply back when/if it happens again.
- Blarn_KranstonNov 30, 2023Apprentice
It took a while, but it finally happened again. The 2.4 Ghz just dissappeared. The network named AT&T is no longer visible as a broadcasted SSID.
The WAX615 is running V10.6.1.2, and I have updated firmware every time a new version comes out.
Here are the log files I downloaded before I rebooted the device.
Any ideas would be much appreciated. This is frustrating when it happens during the work day and half our equipment goes offline.
- PramendraDec 14, 2023NETGEAR Expert
Hi,
Thanks for reporting the issue. We are taking a look at the logs and will update as soon as possible.
Thanks!
Pramendra Singh
NETGEAR SMB Wireless Team
