Blarn_Kranston
Jun 21, 2023Apprentice
WAX-615 2.4 Ghz network dissappears
I have a single WAX615 in my home that is NOT cloud managed. I have it set to reboot every morning at 7:30am to make certain it is running cleanly every day as my wife and I both work from home. ...
- Dec 15, 2023
Hi,
From the logs shared by you, we could find some issue with "Network Integrity Check" feature. We will be improving this feature by fixing the issue in the near future.
For now, we will request to disable this feature. Same can be disabled by going to "Management-> Advanced-> General -> Network Integrity Check" tab.
Thanks!
Pramendra
Pramendra
Dec 15, 2023NETGEAR Expert
Hi,
Thanks!
Pramendra
