Peter30457
Dec 09, 2024Aspirant
WAX 615 has trouble starting up
Have just fired up my new wax615 access point. I cannot log in and it is not acting as a useable wifi. Unfortunately all I am getting is a series of flashing lights. The power/cloud button cycles thr...
Peter30457
Dec 11, 2024Aspirant
Thanks for your reply.I did as you suggested and connected my iMac straight to the router via ethernet and it seemed to work fine. The router is a Deutche Telecom Speedport Smart 4. It is not that old. I have looked right though the GUI and cannot see anything that helps with DHCP. Thoughts.....
Pramendra
Dec 11, 2024NETGEAR Expert
Hi Peter30457
>>> The power/cloud button cycles through blue, green and amber
Based on the LED status in your first email, it appears that the AP is acting as an extender and looking for a root to form a mesh network.
If this is unintended, the AP might be unable to reach the internet and gateway, possibly due to not getting an IP from the router or a loose/faulty cable.
I suggest factory resetting the AP by pressing the reset pin for at least 10 seconds and then releasing it. After this, check if you can see the default SSID (NETGEARXXXXX_SETUP). If yes, the AP is good to go.
Thanks!
Pramendra
NETGEAR NFB Wireless Team
