jhibbard
Nov 18, 2023Aspirant
WAX 625 on Spectrum
I have a functioning Spectrum internet account. It consists of a Spectrum modem (model: U10C153.10), a Spectrum wireless router (model: no info), a Netgear WAX 625 AP and a GS 348 PP. Current phy...
- Nov 19, 2023
jhibbard wrote:
Thank you for the response. I have the manual. I don't find any info on using this AP as a basic router.
That was my suspicion. Depending on how much you pay to rent the router, It might be cheaper to buy one for your own use.
I am not familiar with the WAX625 devices. They seem to be designed for businesses rather than the average domestic network.
Why did you pick that device? It seems to be designed to add a "Managed Wifi" PoE network to a commercial operation. I'd ditch and get a capable domestic router.
michaelkenward
Nov 19, 2023Guru - Experienced User
jhibbard wrote:
However, if I simply unplug the Spectrum router (both power and ethernet) and plug the ethrnet cable into the WAX 625, I can get wired connectivity (sporadically) _AND_ no internet connectivity.
You can't just plug and unplug devices and expect the network to pick up the pieces.
Looking at this:
Spectrum router <=> GS 348 <=> WAX 625
I assume that the GS348 is a switch. This should come after whatever you use as the router on the network.
If this anonymous Spectrum router is functioning as a router, then the WAX625 may (should) be in access point mode to avoid clashes with the main router.
Netgear sells this as an access point. If it is set up as that, then remove the Spectrum router and your network does not have a router.
- What does work is to plug the desktop into the modem; I'm guessing this means that connecting to the internet _without_ the Spectrum wireless router means that internet connectivity does not require the Spectrum wireless router.
That's because the PC is getting its Internet connection from the modem. The router is there so that you can connect all the other stuff to the network.
Some WAX devices can operate as a basic router. I leave it to you to look in the manual for advice on that. At a quick glance, I can't see any indication that this is possible.
Or you could try posting in the bit of this community where they talk about these devices.
Business Wireless - NETGEAR Communities
jhibbard
Nov 19, 2023Aspirant
