PhilBest313
Jul 01, 2024Aspirant
WAX Speeds too slow
Approximately 12 months ago, I purchased the GS108PE-300AUS as well as 4 WAX214 access points. The system as a whole works very well, however I have been experiencing very slow data rates when conne...
PhilBest313
NETGEAR WAX Published Speed Specification lists 600MBps at 2.5GHz and 1200MBps at 5GHz.
Our Ookla Speedtest to different speed-test access points, shows a speed between the WAX and NETGEAR switch GS108PE-300AUS (firmware updated) is only 44Mbps download ans 12Mbps upload.
Please help us find a solution to this low speed problem ASAP.
BrianL
Jul 01, 2024NETGEAR Moderator
Hi PhilBest313,
Welcome to the Community!
You may also want to share the WiFi Clients specs and if the issue is being experienced in both 2.4GHz and 5GHz frequencies.
Kind regards,
BrianL
