nightowl2k2
Aug 12, 2022Aspirant
WAX202 rouge 2.4 GHz endpoint
I have a couple WAX202 WiFi routers and in both cases I am seeing a rogue 2.4Ghz endpoint that shows up after a short amount of time of the router being online. I have seen this happen on 2 devices now and I am concerned that the router firmware was compromised in some way unless someone can explain what the rouge client is. Here are the specifics I am seeing. The device always shows up on the 2.4Ghz band and both routers were just configured after pulling them from the box. They are both running the latest 1.0.5 firmware. The device has an unknown MAC OUI and it does receive a DHCP address but it cannot be ping'd at all. Also, the device still shows up if I change the WPA password on the router. Now, it does not show up right away but does show up after a short amount of time.
My questions:
1) Has anyone else seen this? If so, what were your experiences
2) Is this something part of the Netgear WAX202 firmware? If so, what is it?
Are you using any ios devices? If so, disable icloud relay and private mac/ip address.
- nightowl2k2Aspirant
I can also disconnect my Mac and I still see an endpoint connected to the 2.4Ghz radio. So that also clears the Mac Internet relay function.
