CV91913
Oct 08, 2022Aspirant
Wax206 Access Control
I Just Purchased A WAX206 To Use As An Access Point For My R7900P Router. If I Have Access Control Set Up On The 7900, do I Also Need To Set Up On The WAX206?
- Oct 09, 2022
Oh big sorry please, I stand corrected. Had checked a R7900 instead of a R7900P. This model does have a single simple network ACL, indeed.
Said that, if you insist of managing device level MAC address ACL, both the R7900P and the WAX206 ACLs do the same style of filtering. So to have a MAC ACL to add an additional layer of control, you need to configure and maintain the ACL on both devices.
Sorry again 8-) Lack of coffee here...
schumaku
Oct 09, 2022Guru - Experienced User
Depends what kind of access control you have in mind. What is available on the Netgear routers like your R7900 in router mode differs essentially form what we can do an an access point level.
"Block all new devices from connecting. With this setting, a new device cannot access your router’s Internet connection, but can still access your router’s local network. Before a device accesses your router’s Internet connection, you must enter its MAC address for an Ethernet connection and its MAC address for a WiFi connection in the allowed list."
A wireless access point is a bridge between the wireless network and the wired network (LAN):
"You can use access control to block or allow device access to your network. An access control list (ACL) functions with the MAC addresses of wired and WiFi devices that can either access your entire network or are blocked from accessing your entire network."
Source: WiFi 6 AX1800/AX3200 Dual Band Wireless Access Points, WAX202 and WAX206 User Manual p.76 ff.
CV91913
Oct 09, 2022Aspirant
Thanks For The Reply .
I Have Access Control Enabled On The R7900 Blocking All New Connections. When I Add The WAX206 As An Access Point To The Network, Is The ACL On The R7900 Sufficient To Block Access To The Network Or Do I Need To Enable Access Control On The WAX206 As Well?
