CV91913
Oct 08, 2022Aspirant
Wax206 Access Control
I Just Purchased A WAX206 To Use As An Access Point For My R7900P Router. If I Have Access Control Set Up On The 7900, do I Also Need To Set Up On The WAX206?
- Oct 09, 2022
Oh big sorry please, I stand corrected. Had checked a R7900 instead of a R7900P. This model does have a single simple network ACL, indeed.
Said that, if you insist of managing device level MAC address ACL, both the R7900P and the WAX206 ACLs do the same style of filtering. So to have a MAC ACL to add an additional layer of control, you need to configure and maintain the ACL on both devices.
Sorry again 8-) Lack of coffee here...
CV91913
Oct 09, 2022Aspirant
Thanks For The Reply .
I Have Access Control Enabled On The R7900 Blocking All New Connections. When I Add The WAX206 As An Access Point To The Network, Is The ACL On The R7900 Sufficient To Block Access To The Network Or Do I Need To Enable Access Control On The WAX206 As Well?
schumaku
Oct 09, 2022Guru - Experienced User
Well, please read what exactly this ACL does on the R7900:
It's not a global "Block Access To The Network" - "a new device cannot access your router’s Internet connection, but can still access your router’s local network".
Is this what you really need and want to achieve? Is this worth the effort after all?
the ACL on the WAX206 on the other hand can block any client accessing the local network, including the Internet.
Again, what is the intention for considering this here?
- CV91913Oct 09, 2022Aspirant
Ok, You Have Me Confused. The Documentation And The Actual R7900P User Interface Both Say The Following: You can use access control to block or allow access to your network. It Says Nothing About Blocking Only The Internet.
- schumakuOct 09, 2022Guru - Experienced User
Read everything. Sorry, I know it's confusing. The reference to the details is attached above. Don't blame for strange product specs - I'm not Netgear manager. But again: Why do you think you need this ACL feature? Only clients with the appropriate security config can access the network. Fully managing MAC addresses - leaving alone these privacy enhanced clients defaulting to random MAC addresses .... almost non-manageable networks are - without the help of a management platform - predictable to me. KISS - Have fun!
I Did Read Everything Including The Link. What I Am Saying Is That The Text In The Link And The Text In my Documentation and the UI don't match.
