simeoncran
Aug 08, 2022Aspirant
WAX206 poor 2.4GHz performance
I'm getting very variable and poor ping times to my ESP32 and ESP8266 devices connected to the WAX206. It doesn't seem to matter how close the devices are. This is in an apartment building with lots ...
- Aug 08, 2022
You kind of hit on your problem with the fact that you live in an apartment.
2.4ghz is much more sensitive to interference and has less available channels to use. When a device is broadcasting on 2.4ghz, the other devices on that same channel can't broadcast. You even put that the wax206 you have in an area with less interference, doesn't have an issue.
More than likely the reason it works well for a very short time when changing the channel is that most 2.4ghz routers tend to be set on auto. You'll get that brief period where the router is changing channels that its stops connecting and then works really fast for a bit as the other devices in the complex pickup that it switched. Then it drops back to longer pings as they go back to broadcasting.
Apartment complexes are horrible for 2.4ghz signals. I ran into that same issue a lot until I moved into a detached home. Even then I have some higher ping/latencies because I can still pickup quite a few 2.4ghz signals.
Aug 08, 2022Guru - Experienced User
simeoncran
Aug 10, 2022Aspirant
Thanks plemans, you prompted a bunch more research on my side and I now understand just how little capacity 2.4GHz has in these circumstances. Seems like there's no solution except to accept that these smart plugs will have 20 second latency sometimes. Sad.
