murdof
Dec 10, 2023Tutor
WAX206 seamless roaming
I have 2xWAX206. They are both connected to the same 2.5Gb switch so I'm utilising the 2.5Gb ports on them. I'm trying to identify the ideal settings to enable seamless roaming (if supported) as...
murdof
Dec 11, 2023Tutor
Thanks that's how I have it setup.
I debugged my issue to one of the APs 5GHz band.
When the AP gets a lot of network load (and that happens on 5GHz band) it hangs and needs reboot.
So I have disabled 5GHz on that AP for now till I replace it with another one...
schumaku
Dec 11, 2023Guru - Experienced User
WAX206 Firmware Version 1.0.4.0 current? Something for Netgear QA to look into please hnagaraju please.
- murdofDec 11, 2023Tutor
Yes 1.0.4.0....
I tried to raise a ticket but it the system had some issues so I ended up creating an empty ticket from the bot...
