rickaustinson
Apr 12, 2023Initiate
WAX214 AP network speed incorrect
Hi all, I am in the process of configuring threeX WAX214 APs for a new setup. On the device status page, the LAN speed is being reported at only 100 mbps. It's plugged into a gigabit POE injector...
- Apr 12, 2023
I've also seen sketchy cables cause it to drop. And you're adding in the injector as schumaku says.
Try the external power supply along with a 6ft cable and see what speeds you get. Simplifying is the easiest way to start with finding out if its an AP issue or a cable/injector issue.
rickaustinson
The POE injector is a Xirrus XP1-MSI-75M. It is a 75 watt PoE+ injector, we used to use these to run 8 radio enterprise grade APs, so it should be able to drive a 2 radio AP just fine.
The cable from the switch to the injector is a high quality factory-made cable that I use as my standard "test" cable because its so reliable. The final cable that goes from the injector into the AP however is a short cable I made myself, and I'll admit to not having had the best of luck in that arena.
So I bypassed the injector and used the supplied 12 volt wall war power supply, and on the factory-made cable directly to the switch, immediately got 1gbps. So then I moved it back over to the injector, swapping another factory-made cable in between the injector and the Ap, and guess what?
I got 1gbps.
So my home-made cat6 cable was at fault. Seems I am just useless at rolling my own cables.
Thanks!
Apr 12, 2023Guru - Experienced User
Sounds like you got the issue figured out!
Might just need to redo the ends on the home made cable. I've seen slight nicks or not quite crimped right cause problems.
