twelvexs
Jun 21, 2021Initiate
WAX214 Cannot Set Transmit Power
2 WAX214 APs within property. Want to adjust transmit power for coverage as needed. Updated firmware to 1.0.3.3. No issues with connectivity or dropping connections, but management window will no...
Jun 21, 2021Guru - Experienced User
Justs reinstalled my WAX218 to test it.
I'm on firmware version 1.0.3.2 and it wouldn't work either.
Upgraded to 1.0.3.3 and did a factory reset/reinstall but that didn't help either.
- ChristineTJun 21, 2021NETGEAR Employee Retired
Hello twelvexs
I've asked JohnC_V to check on this and escalate the issue to our internal teams for further investigation.
plemans , Thanks for the shout out! :-)
JohnC_V - Please update this thread with your findings and offer any possible solution(s) if available.
Cheers,
ChristineT
