twelvexs
Jun 21, 2021Initiate
WAX214 Cannot Set Transmit Power
2 WAX214 APs within property. Want to adjust transmit power for coverage as needed. Updated firmware to 1.0.3.3. No issues with connectivity or dropping connections, but management window will no...
JohnC_V
Jun 22, 2021NETGEAR Employee Retired
As per checking, under firmware 1.0.2.3 release notes:
New Features and Enhancements:
- Now Auto RF is enabled always for both 2.4GHz and 5GHz radios. Manual transmit power selection is not supported.
This was also raised as a feature request for WAX214 to be able to change the transmission power manually.
John
NETGEAR Community Team
- twelvexsJun 22, 2021Initiate
Thanks for the reply. I didn't read that release note unfortunately as I went straight to the 1.0.3.3 firmware that's on the web here. That release didn't have that information.
Thanks again and hopefully it's modification capability will be considered in a future firmware release.
- plemansAug 20, 2021Guru - Experienced User
twelvexs Looks like transmit power control for wax214/218 was added on the latest firmware.
https://kb.netgear.com/000063931/WAX214-Firmware-Version-2-0-1-2?article=000063931
https://www.netgear.com/support/product/WAX214.aspx
