Olivier_GAUJAC
Aug 31, 2021Follower
WAX214 Day_zero config mot de passe
During the day_zero config, the Access Point does'nt accep my PassPhrase. It is 1192RuedesTilleuls! 8 to 32 characters OK One Uppercase letter OK One Lowercase letter OK One number OK A symbol ...
DaneA
Aug 31, 2021NETGEAR Employee Retired
Welcome to the community! :)
Its strange that it won't accept it. Kindly try to perform a factory reset on your WAX214 then check if the same problem will occur.
DaneA
NETGEAR Community Team
