t0mb0
May 03, 2021Aspirant
WAX214 maximum real world throughput issue
Hi, I've just installed a WAX214 access point. The maximum throughput I can achieve using 5Ghz Wifi 6 with 80Mhz channels is about 540Mbps. I realise that real life speeds are less than the the...
schumaku
May 11, 2021Guru - Experienced User
t0mb0 wrote:I've just installed a WAX214 access point. The maximum throughput I can achieve using 5Ghz Wifi 6 with 80Mhz channels is about 540Mbps. ... I've tried an iPad, an iPhone and an M1 Macbook, all a negligible distance from the AP, which are all full Wifi 6 devices and they all cap out at close to 540Mbps.
Ok, instead of digging in the dark - what does the Macbook WiFi diagnostics show for the M1 connection?
