drixter
Apr 25, 2022Aspirant
WAX214 missing 5GHz channels
Hello All, I've just implemented WAX214 and notice that not all 5GHz channels are available. Country is set to Poland. U-NII-1 Ch 36: 5.180 GHz Ch 40: 5.200 GHz Ch 44: 5.220 GHz Ch 48: 5.24...
drixter
Hello,
Yes: 2.1.1.2
Thanks,
drixter
Apr 28, 2022Aspirant
Hello,
Any chance for update, because if channel is set to 80MHz then finally only one channel can be used which make this device very limited.
Thanks,
- drixterMay 04, 2022Aspirant
Hello,
Kindly reminder.
Thanks,
- JeraldMMay 04, 2022NETGEAR Employee Retired
Hi drixter,
Upon inquiry, we don't have the certification for those channels.
JeraldM
NETGEAR Community Team
Hi,
Thanks for the answer.
Do you plan to make DFS certification for WAX214?
I'm asking, because I just want to be sure that this will come on some days or consider to replace device, probably other vendor because this information is quite hidden for customers...
Thanks,
