RegularJoe
Feb 17, 2023Guide
WAX214 signal not visible to wifi laptop
Just rec'd this item. Intend on using this access point to communicate with wifi surveillance cams around property. I have it powered up, all lights ablaze... it's putting out the "config" signal,...
RegularJoe
Feb 17, 2023Guide
Well, it may just be my laptop. Had another persons' laptop brought in, and it is detecting the signal alright. Might have to use theirs to set it up.
