dumbo25's avatar
dumbo25
Tutor
Dec 05, 2021
WAX214 SSDP help requested
I have a python script called vadim.py that uses ssdp to discover devices on my network. See full script at https://github.com/dumbo25/wemosetup and vadim.py   The goal of the script is to find al...
  • dumbo25's avatar
    dumbo25
    Dec 08, 2021
    I went back through the JGS524PE settings. The one that seems to make a difference is QoS Mode, which I changed from 802.1p-based to Port-based. And now the script works! Yay! Thank you!
ProSupport for Business
