WTomP
Apr 30, 2023Aspirant
WAX214v2
Just bought 3 of these for my home which has solid walls. It seems a new model with little info on Netgear and I am not sure if 214v1 advice remains good. - such as same SSID for all 3 Advice...
schumaku
May 01, 2023Guru - Experienced User
Tell us about the installation and design idea behind these three WAX214v2 please.
If reading about three APs and thick walls, I'm missing a switch (ideally PoE+), the cabling, and the Hilti to dig some holes through the walls.
Sure, these devices can serve one SSID.
- WTomPMay 08, 2023Aspirant
Sorry for late reply as Netgear keep asking to reset my password, even though I entered the previously rest one.
I found this advice online
" these are the most important things to do:
- Same SSID, passphrase and security settings on all APs
- Different channel for each AP. Ideally non-overlapping (1, 6, 11)"
Does this make sense as I have seen conflicting advice online?
- schumakuMay 08, 2023Guru - Experienced User
Sound advice - as long as we talk of the 2.4 GHz band and the US/FCC channels.
Still unclear to me on how you intend to connect the WAX214v2 to the primary network and router.
