maddhater
May 13, 2022Tutor
WAX218PA Firmware Updates
Is this product discontinued? I just bought it and I can't find any resources even the firmware on the website.
- May 13, 2022
The WAX218PA is just a wax218 with a power supply.
You can find guides, firmware here: WAX218 | WiFi 6 Access Point | NETGEAR Support
May 13, 2022Guru - Experienced User
- maddhaterMay 13, 2022Tutor
What's the difference between MIB and Firmware?
- plemansMay 13, 2022Guru - Experienced User
MIB is more for rolling it out to your whole system. Use the firmware image.
Try an earlier version instead of jumping to the latest.
Looks like the firmware isn't compatible. Any advice?
- plemansMay 13, 2022Guru - Experienced Useralso make sure you extract the file before trying to upload it.
