Jashby90
Apr 10, 2024Tutor
WAX220 new set up - password incorrect issue...it's not wrong password
I have just got WAX 220. Connected via ethernet to by NetGear unmanaged 24 port switch. which is connected to my existing router (SKY - for now!) Easily set up the new password and network name t...
schumaku
Apr 10, 2024Guru - Experienced User
Hi Jashby90
Haven't mixed-up e.g. the admin(istration) login password, the management interface wireless SSID password/passphrase (which does time-out after about 15 minutes), and one of the up to four wireless SSIDs and the related passphrase somehow?
Have set the expected security like WPA2-Personal, WPA3-Personal, or some mixed mode with WPA2-/WPA3-Personal?
- Jashby90Apr 11, 2024TutorI will triple check again but definitely putting in the newly created network password. I screenshotted for reference. See below.
- schumakuApr 11, 2024Guru - Experienced User
Was this wireless connection (on the client) configured from scratch, or had used the same SSID before deploying the WAX220? For example if you had used the "XX Whatever" SSID before, but always on WPA2-PSK (WPA2-Personal), and using WPA3-Personal or WPA2/WPA3-Personal, it's very likely the client does refuse to connect with a kind of wrong password message. In that case forget (remove, drop, ... the wireless connection from all clients, let them search for the WiFi again, and enter the passphrase again to connect.
Key reason for this is the mandatory PMF frames, which must be enabled when WPA3 is operated btw.
- NiveditaApr 11, 2024NETGEAR Expert
Hi,
If you are sure with the configured password and still facing the issue, then as a quick workaround could you please try changing the password from AP GUI for your 'JA OFFICE' network name and recheck?.
Thank you.
