Jashby90
Apr 10, 2024Tutor
WAX220 new set up - password incorrect issue...it's not wrong password
I have just got WAX 220. Connected via ethernet to by NetGear unmanaged 24 port switch. which is connected to my existing router (SKY - for now!) Easily set up the new password and network name t...
Nivedita
Apr 10, 2024NETGEAR Expert
Hi,
Please try to use the right password.
There are three different passwords.
1. WiFi Password for connecting to Management/CONFIG-ONLY SSID (This will be printed on the hardware label)
2. AP login Password (Which you would have set during the Initial setup)
3. First SSID (Network name) Password (Which you would have set during the Initial setup)
You can check the configured SSID password in the AP GUI page also.
Thank you!
