VinceDucat
Mar 30, 2023Tutor
WAX220 poor Web UI for MAC Filtering
Hello, i bought WAX220 to replace WAX206.
i'm very desappointed beacause of the poor quality of the MAC adresse filtering.
in the WAX206, there is a view showing the device trying to connect and i can simply autorised the device to connect, il the WAX220, its very more complicated... no view of the device trying to connect so need to read the log to view witch device try to connect and after that cut/copy information to the MAC list .... 😞
i hope future firmware could had a mean to be more easy ...
so Wifi quality very good
UI quality very bad ...
Hope a reply from netgear teams
regards
Head to Dashboard -> Connections ... with a simple click on [Block] you can add a MAC to the access block list (and vice versa):
thanks for your quick answer
If the choice is to autorized by default, your solution is ok...
but for security reason, my choice was to denied by default and to autorised even there is no security ... 😞
the same fonction with an "allow" button would be great 😉
No chance to add this feature in a next firmware ?
- sharskaAspirant
Hey everyone! Just wanted to chime in and share my thoughts on the topic of the WAX220's poor web UI for MAC filtering.
Having a clear view of devices attempting to connect and easily authorizing them is a convenient feature that seems to be missing in the WAX220. Instead, users are forced to navigate through logs to identify connecting devices and manually add them to the MAC list. That's quite a hassle, and I totally understand the frustration expressed here.
I'm hopeful that Netgear's future firmware updates will address these issues and introduce improvements to make the process more user-friendly.
Let's hope the Netgear team takes note of this feedback and provides a helpful response. Here's to smoother and more intuitive MAC filtering experiences in the future! Regards to all.
- May 21, 2023Retired_Member
