destrosed's avatar
destrosed
CAX30 cable connection status: poor
I'm not too familiar with how  routers work  and  what not. Is this issue on  my  end or  the ISP? How  would  you fix this  issue?
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel693000000 HzLocked
Connectivity StateIn progressUpstream Parameters Acquired
Boot StateIn progressUnknown
SecurityFailedBPI+
IP Provisioning ModeHonor MDDIPv4 only
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
1Locked256 QAM24693000000 Hz8.6 dBmV40.2 dB3629043682
2Locked256 QAM1555000000 Hz10.2 dBmV40.9 dB00
3Locked256 QAM2561000000 Hz10.1 dBmV40.6 dB00
4Locked256 QAM3567000000 Hz10.3 dBmV41.1 dB00
5Locked256 QAM4573000000 Hz10.3 dBmV41.2 dB00
6Locked256 QAM5579000000 Hz10.2 dBmV41.1 dB00
7Locked256 QAM6585000000 Hz10.2 dBmV41.0 dB00
8Locked256 QAM7591000000 Hz10.3 dBmV41.1 dB00
9Locked256 QAM8597000000 Hz10.4 dBmV41.1 dB00
10Locked256 QAM9603000000 Hz10.4 dBmV40.9 dB00
11Locked256 QAM10609000000 Hz10.3 dBmV40.9 dB00
12Locked256 QAM11615000000 Hz10.3 dBmV40.8 dB00
13Locked256 QAM12621000000 Hz10.3 dBmV40.8 dB00
14Locked256 QAM13627000000 Hz10.2 dBmV40.8 dB00
15Locked256 QAM14633000000 Hz10.2 dBmV40.8 dB00
16Locked256 QAM15639000000 Hz10.2 dBmV40.9 dB00
17Locked256 QAM16645000000 Hz10.0 dBmV40.7 dB00
18Locked256 QAM17651000000 Hz10.1 dBmV40.6 dB283
19Locked256 QAM18657000000 Hz10.1 dBmV40.6 dB00
20Locked256 QAM19663000000 Hz10.0 dBmV40.5 dB00
21Locked256 QAM20669000000 Hz9.8 dBmV40.5 dB28711
22Locked256 QAM21675000000 Hz9.8 dBmV40.2 dB400
23Locked256 QAM22681000000 Hz9.5 dBmV40.6 dB140
24Locked256 QAM23687000000 Hz9.3 dBmV40.5 dB1275916568
25Locked256 QAM25699000000 Hz7.9 dBmV40.0 dB1141120888
26Locked256 QAM26705000000 Hz6.8 dBmV39.6 dB55014102497
27Locked256 QAM27711000000 Hz5.4 dBmV39.1 dB5045693657
28Locked256 QAM28717000000 Hz5.5 dBmV39.2 dB45050151509
29Locked256 QAM29723000000 Hz6.7 dBmV39.5 dB54855187697
30Locked256 QAM30729000000 Hz7.9 dBmV39.8 dB1392941546
31Locked256 QAM31735000000 Hz8.6 dBmV39.9 dB7311481
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec36000000 Hz42.8 dBmV
2LockedATDMA25120 Ksym/sec29600000 Hz42.8 dBmV
3LockedATDMA35120 Ksym/sec23200000 Hz42.8 dBmV
4LockedATDMA45120 Ksym/sec18400000 Hz42.3 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
Downstream OFDM Channels
ChannelChannel IDFrequencyPowerSNR/MERActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
133865000000 Hz11.3 dBmV39.6 dB1108 ~ 298762056738810
200 Hz0 dBmV0 dB0 ~ 000
Upstream OFDMA Channels
ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
1 Other0 MHz0 ~ 000 dBmV
2 Other0 MHz0 ~ 000 dBmV
  • FURRYe38's avatar
    Please post a copy and paste of the modems event log page.
    Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
    Power levels are too hight and all over the place:
    https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
    Correctables and un-correctables should be zeros like the other channels.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    https://highspeed.tips/docsis-events/
  • Thank  you for the  response. I'm currently looking at my line and where they  went  into my house they spliced  a  RG6  coax cable to another  cable and hung it  above a rafter in t he  basement then pullled it  through to reach the upstairs.  Not sure if that's anything  to do  with  it but thank you so I  do have  a place to start.
    My Router: CAX30
    Firmware Version V2.2.4.2
    Event Log
    Clear Log Refresh
    TimePriorityDescription
    2025-11-13 07:47:50Error (4)DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:52Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:47Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Notice (6)TLV-11 - unrecognized OID;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Error (4)Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 20:03:46Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    1970-01-01 00:00:34Notice (6)Honoring MDD; IP provisioning mode = IPv4
    1970-01-01 00:00:31Critical (3)No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    1970-01-01 00:00:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    2025-11-12 18:18:41Critical (3)No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    1970-01-01 00:00:28Critical (3)No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    1970-01-01 00:00:23Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
    2025-10-22 19:33:06Critical (3)No Ranging Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-22 13:20:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-20 12:55:10Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-05 07:54:00Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-04 16:31:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-03 12:53:34Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-03 00:43:33Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-10-02 15:32:16Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-30 10:55:59Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-23 15:09:44Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-21 20:15:37Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-18 14:20:04Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-17 17:33:34Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-17 12:43:32Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-16 16:47:24Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    2025-09-15 14:36:31Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=e0:46:ee:fb:3c:07;CMTS-MAC=00:01:5c:a5:ac:52;CM-QOS=1.1;CM-VER=3.1;
    • FURRYe38's avatar
      Ya you got lots of criticals and errors that the ISP needs to look at.
