jayzk123
Mar 25, 2023Aspirant
WAX610 - Multiple WAP + DHCP issues
Hello, For our small business, I am using 3 WAX610 - with same SSID and fast roaming enabled. My topology is 1. ISP Modem/Gateway (Hitron) connected to a 2. TPLink unmanaged POE Switch c...
schumaku
Mar 26, 2023Guru - Experienced User
Unlikely, another switch will hand out addresses from the 192.168.1.0 IP subnet network.
Similar, the WAX610 does not have an on-board DHCP server, except you have configured an SSID NAT mode (default in the 172.31.0.0 address range) and configured a different IP pool. However, this SSID NAT mode would allow Internet access then.
Best guess some other device, like another consumer or SOHO router is active on the same network.
- jayzk123Mar 26, 2023AspirantIs there a way to find this other dhcp server?
Any tools or tricks that I could use?
