jayzk123
Mar 25, 2023Aspirant
WAX610 - Multiple WAP + DHCP issues
Hello, For our small business, I am using 3 WAX610 - with same SSID and fast roaming enabled. My topology is 1. ISP Modem/Gateway (Hitron) connected to a 2. TPLink unmanaged POE Switch c...
schumaku
Mar 26, 2023Guru - Experienced User
Unlikely, another switch will hand out addresses from the 192.168.1.0 IP subnet network.
Similar, the WAX610 does not have an on-board DHCP server, except you have configured an SSID NAT mode (default in the 172.31.0.0 address range) and configured a different IP pool. However, this SSID NAT mode would allow Internet access then.
Best guess some other device, like another consumer or SOHO router is active on the same network.
jayzk123
Mar 26, 2023Aspirant
Is there a way to find this other dhcp server?
Any tools or tricks that I could use?
