RN7
Mar 10, 2023Aspirant
Wax610 5ghz not working on certain devices. Specially on my S22 ultra.
MY 5ghz is not working in my s22 ultra. it works with other routers with 5ghz. on the other hand my iphones work perfectly with my AP's 5ghz. how to solve the issue?
Mar 10, 2023Guru - Experienced User
Do other devices see the WAX's 5ghz?
Just not the S22?
- abacqdghfthMar 13, 2023Guide
Hello,
Can you please share few more details
1) SSID Security configurations : WAP2-PSK or WPA3-PSK or WPA2/WPA3 Mixed mode ?
2) Is 802.11w (PMF) enabled or optional ?
3) what is radio mode set ?
or you you send just us the techsupport log file and enable diagnostic (SD . It will help us.
- RN7Mar 14, 2023Aspirant
2) Is 802.11w (PMF): Disabled
3) what is radio mode set?: 11ax
- RN7May 11, 2024Aspirant
Suddenly the subscription of my AP got over therefore can't control it via the insight app. Is it the issue for the device cannot be found? How to solve the issue. Also, the location light used to be blue, now it's yellow.
Yes. Other devices see AP's 5Ghz. for example, my laptop, iphone 14 pro max.
