matthelm75's avatar
matthelm75
Initiate
May 03, 2020
Device manager on iOS not working ('No Device Found!)
Just noticed this problem today.  Everything is connected, but on the Nighthawk App, when I select the Device Manager, it says that 'No Device Found' although everything is working.
I checked the routerlogin.net page, and it lists the 20 devices that are connected.  Problem seems to be with the iOS Nighthawk App.
  • matthelm75's avatar
    matthelm75
    Jun 03, 2020
    Problem was the iOS app.  Once that was updated and I downloaded the latest update - then it worked.
    • michaelkenward's avatar
      michaelkenward
      HomeITgotoguy3 wrote:
      I'm having the same issue. Please fix ASAP.
      Sniff around and you will find many many reports of the same thing.
      Lots of different hardware hit.
      • JamesENicholson's avatar
        JamesENicholson
        This feature worked initially when I installed the system a few weeks ago.  Either a firmware upgrade or an iOS app upgrade has rendered the "connections" invisible.  I can no longer see the 10-15-20 devices I have connected via wifi.  Annoying.
