ortizalfredt
Apr 26, 2026Aspirant
WAX610 Band Choosing
Is there a way to move an 2 band eligible device from one band to the other? (2.5=>5 or 5=>)? I'm using browser (not insight) management
- Apr 27, 2026
schumaku wrote:
For what reason you want to force a 5 GHz client connecting to a 2.4 GHz radio, respective forcing one connecting to the 2,4 GHz GHz radio to a 5 GHz radio?
It would be helpful to know this.
If you really need this functionality, you can set up different SSIDs for each band, and then configure each client to connect to the appropriate SSID.
