arainer
Jul 21, 2021Aspirant
WAX610 ceiling mount incompatibility and advice
Hello, I got pre-installed AP drops in my new house. I bought some NETGEAR WAX610 APs and I’m trying to mount them, but it seems like i don’t have a compatible fit. The holes are just 1/8” too fa...
schumaku
Jul 21, 2021Guru - Experienced User
Add an additional hole into the AP mounting plate, or extend one or both mount hopes by about 1.5 mm each.
arainer
Hi, not sure if it is noticable in my photos, but the celling is a wide drop and the AP mounting plate is very small--smaller than the AP's mount holes. Maybe I can fashion a thin piece of wood and put holes in it? I worry about the heat though so not sure if that is the best approach.
- schumakuJul 21, 2021Guru - Experienced User
There is also a mounting plate supplied with the WAX 610 - I would make these two holes "fit" to this plate, and clip the WAX on it.
- arainerJul 21, 2021Aspirant
Thanks again for your response. Unless I am missing it, I do not think a mounting plate comes. All the accessories I have are in the OP images. Per NETGEAR guide for WAX610: https://www.downloads.netgear.com/files/GDC/WAX610/WAX610_IG_EN.pdf
Looks like it does not. Can I buy one somewhere?
- schumakuJul 21, 2021Guru - Experienced UserThere are two mounting brackets in fact....
Mounting bracket with screw holes for
mounting to a solid ceiling or 15/16 in.
(23.8 mm) T-bar.
Thats the obe which should be adopted in my opinion.
