rhal
Nov 14, 2022Aspirant
Wax610 default username password
Hello Community, what is the default username and password for the wax160 ? I'm trying to access the individual access point to downgrade the firmware because i have very slow connection , i hav...
Nov 14, 2022Guru - Experienced User
when you first setup the access point, it required you to change it from the defaults.
Are you managing it through insight?
or just local access?
not sure if the insight devices have password recovery.
- rhalNov 14, 2022Aspirant
I'm managing through the insight, looks like i don't have any options.
Anyways thanks for the feedback, greatly appreciate.
- plemansNov 15, 2022Guru - Experienced User
You should be able to access it through insight.
- schumakuNov 15, 2022Guru - Experienced User
The location wide admin password is set from the Insight environment.
Via the location -> Devices https://insight.netgear.com/#/devices/dash you have full control on each AP all radio, network Configuration, Radio Channels, Channel Width, Output power ...
Sais that: You have full control of what is going on on your Insight managed APs.
