laurelinme's avatar
Mar 04, 2017
username and password
Hi , I can't find anymore my username and the password for the repeaters and so I'm stuck cause I can't access my extended wifi connection in the house . Does someone know how to reset it ? thanks in advance for your answer
  • There is a physical button to reset it to factory settings.  The button may be recessed inside a hole.  If you don't have the manual, you can download it from support.netgear.com.
