phirestalker
Dec 10, 2022Tutor
WAX610 insight firmware update emails
I receive update emails informing me that there is an update for my WAX610 AP. I check and it says there is no update. Then, days later I check again and there is an update. What is wrong? Why is it ...
Dec 10, 2022Guru - Experienced User
The updates sometimes get uploaded to the manual server first for updates and then later to the automatic updates server. So sometimes you get the email and can manually do it or wait for it to be pushed to the automatic update server.
Did you check the manual one or just the automatic update one?
phirestalker
Dec 10, 2022Tutor
I pressed the "check for update" button in the administration webpage. I also went to downloads section for the AP on the netgear website. It was not there either.
