KarlV
Oct 15, 2021Aspirant
WAX610 Isssue with OneDrive & Sharepoint
I have recently installed a new WAX610 access point replacing an old D-Link AP Everything works well on it, speeds are great, only issue is that One Drive & Sharepoint won't work on any device, I...
DaneA
Oct 19, 2021NETGEAR Employee Retired
Did you encounter an error message whenever you try to connect to One Drive & SharePoint wirelessly through the WAX610? If yes, kindly post a screenshot of it.
What is the current firmware version of your WAX610?
DaneA
NETGEAR Community Team
KarlV
Oct 20, 2021Aspirant
Firmware is up to date 9.5.3.2
Have plugged the AP into another broadband we have off the network and have the same issue, so definetely the AP with the issue
