dhda
May 23, 2022Aspirant
WAX610 needs reboot daily, before clients can connect
Approaching the WAX610 AP, WIFI Analyzer shows the strong signal (-40dB) but Android as well as Windows clients do not connect, not even after switching OFF/ON WIFI. They remain on an AP, too far aw...
RaghuHR
May 24, 2022NETGEAR Expert
Hi dhda Could you please go to monitoring page and download the detailed logs before you reboot the AP? Send me the link to download the logs via PM. We will check the logs and update you.
Thanks,
Raghu.
dhda
May 25, 2022Aspirant
Hi RaghuHR,
Many thanks for your reply.
Around 12:45, went from AP IP ...101 to AP IP ...249 with phone MAC ...56:00:58.
0 Clients on AP 249, (5) clients are connected to AP 101.
Phone does not connect to closest AP (according WiFi Analyzer ddistance <1m / -45dB), not even after WIFI OFF (4G takes over) and back to WIFI ON.
If we would reboot AP 249, it will.
Downloaded Detailed Log or AP 249.
What do you mean with send link via PM (to provide you the log) ?
Best Regards,
Danny
- schumakuMay 25, 2022Guru - Experienced User
Put the log file(s) on any kind of cloud storage which allows to share files using a simple link.
- dhdaMay 25, 2022Aspirant
Should be available in OneDrive : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBb10dZLi8Ir3aB5g?e=xZx00f
In the meanwhile, here's a link of the logfile, after the AP had been restarted : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBcD7nbTJ_G7V_I-w?e=1kuqJY
About 7 clients have been connected since, before this remained 0 clients.
Hope the logfiles can clear something out.
