dhda
May 23, 2022Aspirant
WAX610 needs reboot daily, before clients can connect
Approaching the WAX610 AP, WIFI Analyzer shows the strong signal (-40dB) but Android as well as Windows clients do not connect, not even after switching OFF/ON WIFI. They remain on an AP, too far aw...
schumaku
May 25, 2022Guru - Experienced User
dhda wrote:
What do you mean with send link via PM (to provide you the log) ?
Put the log file(s) on any kind of cloud storage which allows to share files using a simple link.
dhda
May 25, 2022Aspirant
Should be available in OneDrive : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBb10dZLi8Ir3aB5g?e=xZx00f
