roselink
Feb 15, 2024Aspirant
WAX610 Samba TCP Retransmissions
Hi everyone, I recently purchased two WAX610 Access Points for my home. Currently, I am getting about 750 - 850 Mb/s up/down speeds over LAN. This is great! I have confirmed this via iperf3 and a...
- Mar 09, 2024
Just wanted to post a follow-up to this thread. After doing some further research, I discovered that the issue did not lie with the WAX610, and instead lies with my virtual machine & hypervisor. Thank you to the Netgear team for reaching out to me and assisting with diagnosing my issue. Very professional customer service
schumaku
Feb 16, 2024Guru - Experienced User
Hard to imagine WMM will cause such an effect. Have seen issues on adapter, switchport, or cabling issues, much more likely than anything on the AP or the NAS, for example when Jumbo Frames are travelling an environment breaking up frames, leading to retransmission.
- roselinkFeb 16, 2024AspirantIt’s quite bizarre. I tried using the AC adapter instead of my POE injector with no change. My cables all perform perfectly with iperf3 throughput testing. I also tried a 2.5 Mikrotik switch with the AP. The issue may lie with my virtualized SAMBA server. Strangely it is both WAX APs that show the issue. I’m scratching my head
- BrianLFeb 16, 2024NETGEAR Moderator
Hi,
I have sent you a PM.
Kind regards,
