markfMK
Dec 26, 2020Guide
WAX610 Setup Question
Hi, I’ve just received my first WAX610 connected to a POE Switch. I plan on getting a second WAX610 and want that to be connected directly to the switch but have the same SSID as primary WAX610....
markfMK
Dec 26, 2020Guide
Thank you for the quick response!
Is there an easy way to configure them all? Or a manual task on each AP?
Thank you again for your support. Mark
schumaku
Dec 26, 2020Guru - Experienced User
Insight Managed WiFi 6 AX1800 Dual Band Access Point Models WAX610 and WAX610Y User Manual p.76 "Enable or disable band steering with 802.11k RRM and 802.11v WiFi network management"
