Smears
Apr 02, 2023Tutor
WAX610 Slow
I bought 2, one for house and the other for the man-cave. They arrived today. I have synchronous gigabit (fiber) internet. Hardwired speed test using fast.com shows about 900Mbps each direction. Using...
BasuKhodanapur
Apr 02, 2023Apprentice
Hello Smears
Could you please share below details.
1. Clients details, in which client seeing less speed, like Client Model, version and make etc.
2. Access Point configuration, details like SSID level configurations channel, bandwidth, Vlan and If any rate limit configuration
3. If possible Netgear insight account details, You can dm me account details.
Thanks,
Basavaraj
Smears
Jun 07, 2023Tutor
Sorry for the really late response. They are configured as they came out of the box, with only an SSID configured. Nothing else was changed from factory setting.
When I power on the AP it will get amazing speeds (400Mbps+) but then the AP goes in to its configuration mode (2.4 and 5 lights blank out for about 30 seconds), and when it finishes I get about 200Mbps. My internet connection is 1Gbps. The AP's test (using insight app) at about 920Mbps... so I know they're getting full bandwidth via hardwire.
